speedo not working
92 hatch
speedo not working
Post by 92 hatch »
Whats up,
my speedameter was working fine before i installed my lighten flywheel. when i was done with everything took it for a test drive and notice that when i give it gas the speedo dont work when i let go of the gas it shows the speed. LOL. So my question is what is the problem?
92 civic with a z6 motor s20 trans manual tranny
replaced the speedo with another one i had. did the same thing.
any help would be cool. thanks
speedo not working
Post by Phate »
Did you check the cable? Or did you reinstall it correctly?
92 hatch
speedo not working
Post by 92 hatch »
Its a hydro tranny. which cable are you talking about? Is there a wrong way to in stall it.
speedo not working
Post by Phate »
Nvm, I was thinking you had a old cable transmission.
92 hatch
speedo not working
Post by 92 hatch »
yeah its kinda weird worked fine one day next it didnt.
Doing some resreach on google, some people where talking about a faulty ignition switch.
What do you think ever heard of that?
crx08
speedo not working
Post by crx08 »
ignition switch wouldn't cause the speedometer to not work properly. faulty speedometer sensor on the transmission?
stl-imports.com/forums
92 hatch
speedo not working
Post by 92 hatch »
thats what i thought. thank you
why would it register the speed when i am not giving it gas. then i give it gas and it drops to zero. tach works fine.
crx08
speedo not working
Post by crx08 »
sounds like a electrical short some where. where? idk
92 hatch
speedo not working
Post by 92 hatch »
LOL thanks bro
NOt what i wanted to read. but thank you for your imput
Now to put some time aside to search. :(
God Bless you thanks again
crx08
speedo not working
Post by crx08 »
look for exposed wires? and/or loose connections
