Almost stuck at a light!
02Type-S
Post by 02Type-S »
So I was in the Integra today, and when the light turned green, I could not get it to go into ANY gear. Not even reverse. Acting like the clutch wasnt engaged. I finally got it into 3rd and rode the clutch thru the light, then it hesitantly started going into the gears, but when its in gear, and i use the clutch, the pedal seems to shudder a little as i let off of it, then when i put it in neutral, the clutch seems fine.
WTF? Bad fluid? Bad slave cylinder? WHat do you think?
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
crx08
Post by crx08 »
maybe air in the system? check your fluid level and the color of it
stl-imports.com/forums
02Type-S
Post by 02Type-S »
It has had intermittent notchy shifting...some days notchy, some days drives perfectly fine. Its weird.
2002 Acura TL-S
crx08
Post by crx08 »
so depends on the day it won't go into gear properly?
02Type-S
Post by 02Type-S »
crx08;229111 wrote:so depends on the day it won't go into gear properly?
Pretty much. It was way worse than its ever been tonite, bc i couldnt get in into gear at ALL. And even once i did, it was acting weird, like it wasnt engaging right, but not slipping.
2002 Acura TL-S
crx08
Post by crx08 »
hmmmm want me to help you check it out some time? if there was a leak you could tell. just look at the clutch master cylinder area to see if there is any fluid there and the slave cylinder area.
02Type-S
Post by 02Type-S »
crx08;229120 wrote:hmmmm want me to help you check it out some time? if there was a leak you could tell. just look at the clutch master cylinder area to see if there is any fluid there and the slave cylinder area.
Ill take a look when its light outside...damn hondas. lol
2002 Acura TL-S
crx08
Post by crx08 »
02Type-S;229122 wrote:Ill take a look when its light outside...damn hondas. lol
lol
02Type-S;229109 wrote:It has had intermittent notchy shifting...some days notchy, some days drives perfectly fine. Its weird.
broken spring on the clutch probley, order a exedy oem replacement clutch off ebay and then call me when you get it and we can swap it in
http://cgi.ebay.com/ebaymotors/EXEDY-CL ... ccessories
02Type-S
Post by 02Type-S »
And this morning it goes into gear just fine...?
2002 Acura TL-S
