Integra transmission in civic????
erming
Hey guys I was looking at an 1993 ls integra 5 speed manual cable transmission to buy for my 1990 honda civic hatch that im swappin a b16 into. I was just wondering will this bolt up to my engine and to my mount with out a problem or will I have problems. Thanx for the help.
The tranny will work with the b16 and the 90 civic, but the gears are kinda long for the B16
erming
Im ignorant to this whole gear thing, whats long whats short?????
Rather than me type it out, these guys do a good job at explaining it
http://www.standardshift.com/forum/view ... =6&t=10270
erming
So basically I wont be revving as quick as I should if i understood that correct but i will have a higher top speed technically. good for gas mileage im guessing right???
erming
Also what about my clutch that I have now would that work with the ls tranny?
Hold the clutch up to the screen so we can get a better look at it. Do you have a large or small spline clutch? Best way to find out is take the disc with you. It should fit on there TIGHT. If it can wobble around, you are probably trying to put a large spline clutch on a small spline trans. If it won't it at all, it's vice versa. DO NOT try to use a hammer to put it on at that point.
