Leaking from Axles?
delslo
Leaking from Axles?
Post by delslo »
Not sure how to word it but, My tranny leaks gear oil from what looks like both sides. It doesn't leak quickly or even drip. Just as I drive it the axels seem to spin it out. I'm sure there are some kind of seals that go into the housing right there that need to be replaced. My Question is:
How hard is it to replace those seals? I'm sure some of you have done it, or put all new axles in. It looks like it wouldn't be to bad, if you just have to loosen the axle and slide it out.
Leaking from Axles?
Yep. Pull the axle out on each side. Pull the old axle seal out. Press the new one in. Cake.
delslo
Leaking from Axles?
Post by delslo »
Schweet! Thanks Rob!
