Can't figure out?
91TegiRollin
Can't figure out?
has it been doing it since you installed the clutch?
Racecore.com
Racecore.com
stlsupra
Can't figure out?
you forgot to say to disconnect the battery, isn't that what every helms set of instructions say to do??btlfedgolf;163875 wrote:Easy as hell.
This is how I did it(although I am sure someone will say I am doing it wrong:
1. put a jack under the clutch arm and jack it up so there is slack in the cable.
2. disconnect the cable from the bracket above the clutch arm
3. disconnect the clutch cable from the arm
4. disconnect the cable from the petal in the car
5. twist and pull of the cable grommet on the firewall.
Bill H.
90 civic Si
not many stock parts left
90 civic Si
Can't figure out?
Why don't you take it back to were you had the clutch installed and tell them to fix it?
Stage 2 clutch...LOL
kikkinasphalt
Can't figure out?
16vshelbyz;163657 wrote:+1
both of you did nothing to help him figure it out....99preludesh;163644 wrote:driver error?
'98 CSVT.. stock
91TegiRollin
Can't figure out?
Hey i like my stage two thats the way i bought my car apparentily it was already installed and so after 4 years it finally broke and so the mechanic fixed it but now my petal just delays for like 5 secs before popping out the rest of the way!
Can't figure out?
so why havent you taken it back and told him its not right? this is what should have been done in the first place insteading of post whoring on here to get to the fs section....
Racecore.com
Racecore.com
99PreludeSh
Black95gsr
Can't figure out?
Exactly. "only 8 posts to go", then 8 posts later the car is up forsale. Ban post whoreHardCore97;163932 wrote:so why havent you taken it back and told him its not right? this is what should have been done in the first place insteading of post whoring on here to get to the fs section....
