Figured that I would put a new clutch and flywheel in when I got the new engine put in the GSR and wanted to know if this looked like a good combo.
http://cgi.ebay.com/ebaymotors/EXEDY-Cl ... 0192096760
I know that EXEDY is a good company for clutches and I have heard of Fidanza but I dont have any experience with them. The flywheel is 7.5lbs so how much lighter than stock is that?
Clutch and Flywheel Question
UMR Racer
CARS
1994 Civic EX SOLD
2001 Acura Integra GSR
1994 Civic EX SOLD
7.5 is under half the weight of stock. DON'T buy it. it is too light for daily driving and you will end up losing a lot of drivability with it. if you want to go lighter buy an XACT streetlite (12.5lbs) or a type R flywheel(about 15-16 lbs) both would serve you much better for getting around in traffic than that fidanza.
UMR Racer
How does the flywheel reduce drivability.
CARS
1994 Civic EX SOLD
1994 Civic EX SOLD
is that a question or a statement?
less weight means less inertia which means that it won't hold RMPs as well...
less weight means it revs up faster, but that means that it slows down faster too because there is no inertia to keep it spinning. for daily driving you rely on the weight of the flywheel for highway driving and traffic, and in instances where you are engaging the clutch... less weight means you have to more precisely rev match in order to avoid bogging or killing the car... more wieght on the flywheel helps the engine 'push' the clutch around and allows more room for error when driving. this is also the reason that light flywheels are crap for drag racing, no inertia means you can't launch the car as well.
hey, if you wanna drive around like a road racer all day, thats fine. I just prefer a little more refinement in a car that I plan on driving everyday.
big pipe
i have the exedy organic stage 1, with a 9lb fidanza in the wrx... i absolutely love it.
the pedal feels lighter than stock, and you really dont notice the flywheel after the first 5 minutes you drive on it. that setups been holding 300+ hp 7000rpm awd launches for 3 years now, hell the stage1 grips hard enough to shred all the teeth off second gear (dont ask how i know). i was a little nervous going from a 23lb flywheel to a 9lb at first, but after i got used to it, i think a 6 or 7 will be next
exedy = topnotch stuff!
i was so impressed, that thats the same setup going in the accord
this space for rent
UMR Racer
Thanks for the clear up. I didnt mean the last statement in a negative way.Spork;96200 wrote:is that a question or a statement?
CARS
1994 Civic EX SOLD
1994 Civic EX SOLD
g3integragsr
I have a fidanza 12.5 pound flywheel and I love it. Wasnt a huge transistion from stock either
12.5 is as light as I would go... i have a streetlite in my basement that I was planning on using, but I think I might get an itr and savor a little more inertia.g3integragsr;96302 wrote:I have a fidanza 12.5 pound flywheel and I love it. Wasnt a huge transistion from stock either
g3integragsr
yeah.....I got it free, only 3k miles on it at mostSpork;96310 wrote:12.5 is as light as I would go... i have a streetlite in my basement that I was planning on using, but I think I might get an itr and savor a little more inertia.
thats the clutch i have, i would just get that clutch kit without the flywheel but get the stock flywheel turned, it is probly the same price if you dont get it on e-gay, mine was $170 or so.big pipe;96205 wrote:i have the exedy organic stage 1, with a 9lb fidanza in the wrx... i absolutely love it.
