Auto Tranny fluid leake
revocast
Post by revocast »
96 prelude w/ an auto tranny fluid leake, i believe its coming from one of the hoses that goes to or leads for the radiator but cant find it, if someone replies soon and could help me that would be great if not i'm probably going to end up takeing it to the local dobbs
Post by rickles8099 »
if you think its one of the hoses, first make sure all the hose clamps are tight and check for holes in the hoses.
revocast
Post by revocast »
right hey cna u move this i out it in the wrong section looking at this ment to put it in engine tech section
revocast;57828 wrote:right hey cna u move this i out it in the wrong section looking at this ment to put it in engine tech section
even better... i put it in the transmission tech section.
revocast
Post by revocast »
well i think i found the problem, the hose either coming out or going in is being pinched under the bottem of the radiator somehow it doesnt look cut, so i'm think take it out reposition. but wat the hell do i do bout all the tranny fluid i lost?
revocast;57870 wrote:well i think i found the problem, the hose either coming out or going in is being pinched under the bottem of the radiator somehow it doesnt look cut, so i'm think take it out reposition. but wat the hell do i do bout all the tranny fluid i lost?
You refill the tranny...
The tranny has a big yellow dipstick on it, you fill the tranny up until it reaches the full mark on the dipstick.
revocast
Post by revocast »
yeah well i went up to dobbs cuz i remembered thats were i did a transmission fluid change when i got the car and they filledit up for free thnx though
300k_CB7
Post by 300k_CB7 »
revocast;58258 wrote:yeah well i went up to dobbs cuz i remembered thats were i did a transmission fluid change when i got the car and they filledit up for free thnx though
Did they use genuine honda ATF Z1? I didn't think they stocked it at Dobbs...
Some non-dealer shops also use to SmartBlend additive by Life Produsts (converts reg. dexron ATF to Honda friction-modified specs), which works well too...
revocast
Post by revocast »
u know i had some problems again and i think ur right i dont think they used the right kind cuz when i went to autosone and asked which type my car took they told me somehting different from wt dobbs put in so yeah not good but i'm repairing it now
