Clutch Help!!! Please fast
teg_timmyc
I Finally got the thing runnin but now for some reason the clutch won't pull in...i have everything hooked up right, i can't even pull the lever up w/ my hand...what do you guys think it is?
I ROCK FACE-V.15245654354684
what kind of car is it?
twkdcd595
what work did you do on the car that is has now developed this problem?
need more info.
need more info.
number one, is it a cable clutch or hydrolic, if cable, did you adjust the clutch cable?
number two, are you sure that the throwout bearing was installed and installed properly?
teg_timmyc
its in an 89 civic and i just put a d16y8 into the car... and used the original tranny, it worked fine when i took it out
what clutch did you use?
teg_timmyc
the one off the d16y8 cause it was pretty new....i know in B series they are all the same ...are D;s different?
b-series is NOT all the same, and i dont think d-series are either... in 92 they switched all of the B, and I believe D series too, trannies to the larger input shafts.
just a quick search of clutchnet's products gave me this:
http://www.clutchnet.com/make/honda.html#Civic
makes it look like the specs are wayyy incompatible.
teg_timmyc
oh well this should be fun then!! i have to pull the tranny out of the car now!!! wooo hooo..... peace!! thanks a lot
