[FONT="Georgia"]So every 3-4 days now, for like this last month my clutch fluid has been draining like crazy, & I keep getting stuck in the middle of busy intersections. =( (not good)
I know I probably shouldn't be driving her until I get this situated but I must get back and forth to work and currently she is my only car.
What would make the clutch fluid drain like that?
I was think my clutch cable has been stretched or maybe has a cut in it?
What do yu guys think?[/FONT]
Clutch Fluids Draining Too Quik!!!
iStick
93Ludetta
follow me on twitter @ScanMyBCode
:honda:
:honda:
There is no clutch cable on a hydraulic clutch system. The most common place for the system to leak is the clutch master cylinder. Check around the clutch master cylinder in the engine bay for leaks as well as inside the cabin near the pushrod that connects the clutch pedal assembly to the master cylinder. If no leaks are found there, inspect the fluid reservoir, hard and soft-lines for any damage. Finally, check the slave cylinder attached to the front of the transmission for signs of leaks. Be sure to pull off the boot covering where the slave cylinder pushes against the clutch fork for a thorough inspection.
iStick
[FONT="Georgia"] ok thxs i'll check those [/FONT]
93Ludetta
:honda:
:honda:
