car broke down
car broke down
Post by HardCore97 »
yes. the cam wont turn the the distributor, which wont turn the rotor
Racecore.com
95_gsrfodo
car broke down
Post by 95_gsrfodo »
civicex;300132 wrote:well saying that would a broken timing belt stop it from getting a spark?
yes it will because the rotor will not spin.. so no spark
motor will spin faster then normal
‎4 Doors = More Whores
civicex
car broke down
Post by civicex »
HardCore97;300134 wrote:yes. the cam wont turn the the distributor, which wont turn the rotor
95_gsrfodo;300135 wrote:yes it will because the rotor will not spin.. so no spark
k thanks guys i'm gonna go pull off my valve cover and return.
PSN: DumbRands
TurboFreak
car broke down
Post by TurboFreak »
well???
Nik
Turbulent Motorsports
I have more torque than GOD!
car broke down
Post by Phate »
Just take off the timing cover.
car broke down
Post by rickles8099 »
did you even check to make sure the phillips screw that holds the rotor in inside the distributor is still in? if it backs out and falls out the rotor will not spin either.
car broke down
I am pretty sure it will still spin. Its keyed, so if its on the shaft it will spin
Markjdmb16
car broke down
Post by Markjdmb16 »
Hmm, i would think it's keyed like all the other Honda motors in that gen on up. Now if it's your timing belt, glwt man, as far as i know, those motors are collision just like the rest of them... I'm not a huge Prelude fan, so don't take my advice to heart, please ask someone else who is more experienced with them, hope you get it fixed, bud!
:yernuts:
crimsoncivic
car broke down
Post by crimsoncivic »
If all else fails check ur grounds
Imagea work in progress
95_gsrfodo
car broke down
crimsoncivic;300202 wrote:If all else fails check ur grounds
no go... he said the dizz rotor isnt spining
