coolant issues with an f22
thewagoneer
Post by thewagoneer »
my 97 wagon is having coolant issues it goes thru almost a gallon of coolant in 450 miles but it docent have a bad head gasket it has a brand new radiator the water pump and thermostat are working properly so im at a loss to why its lossing so much coolant and i run a 50/50 mix in it. The only leak i found was what looks like a vacuum line that goes to the bottom of the throttle body the rubber hose that connects it was dry rot but it had to have started leaking in the past 2 days i dont see how you can lose over half your coolant from that, especially since it was such a small issue. if you could give me some ideas it would be greatly appreciated.
Post by Phate »
What's your oil look like? Are you sure you have the HG installed correctly? Is your radiator cap good?
There are coolant lines on the bottom of the trottlebody on a F22 if they are dry rotting that might be your leak.
thewagoneer
the oil is clean no milky look to it. do you think it could have pushed almost a gallon and 1/2 thru it in 2 days?
Sparky65
Post by Sparky65 »
you will learn really quick, chris, that if something can go wrong, on a honda, it will. Replace all your coolant lines. Especially the ones around your fitv. If those get too bad, you'll have an idle issue.
- 1993 Honda Prelude Si
thewagoneer
Sparky65;298934 wrote:you will learn really quick, chris, that if something can go wrong, on a honda, it will. Replace all your coolant lines. Especially the ones around your fitv. If those get too bad, you'll have an idle issue.
great so there just like hondas mowers well at least i bought a lot of tubing ill just go a head and replace it all and hope for the best. why in the world is there cooling lines that run to the throttle body?
92_luder
Post by 92_luder »
yeah when i did my swap i replaced all my hoses, you might want to check the heater hoses too
Sparky65
Post by Sparky65 »
thewagoneer;298946 wrote:great so there just like hondas mowers well at least i bought a lot of tubing ill just go a head and replace it all and hope for the best. why in the world is there cooling lines that run to the throttle body?
They deal with your FITV (Fast idle thermal valve) that affects your idle before the car is up to operating temp.
