Ok i been working the last little issues out with my car so i can tune for more boost. This issue has me stumbled
I am over boosting it never stops just keeps going. I have a off brand manual boost controller. I have a vacum line coming off the turbo to the bottom wastegate port. A t split half way with a boost controller ran to the top port. With my boost controller turned all the way down it will run off the spring 7psi but if i turn the controller 1 click or 20 clicks it just boost to the max. Any clues why this would happen.
Also i have another boost controller but it acts back wards if i turn boost up it goes down and it i turn down it goes up.
over boosting
Redline
over boosting
More power coming soon
v-tecivic
over boosting
With the manual boost controller, you only need to use the bottom port on the wastegate. It should go from turbo(or other boost source) to bottom nipple on the mbc, then from the mbc to the bottom wastegate port.
97 civic ex turbo
13.1@112
Redline
over boosting
When i had it like that before i would hit my boost mark then creep back down as the rpms went up
over boosting
v-tecivic;292962 wrote:With the manual boost controller, you only need to use the bottom port on the wastegate. It should go from turbo(or other boost source) to bottom nipple on the mbc, then from the mbc to the bottom wastegate port.
Exactly.
When you have it going to the top side you are actually helping push the valve/ diaphragm downward to close the valve....so no exhaust escapes, it just goes into the turbo making it spin more.
Redline
over boosting
Ok thanks guys
Redline
over boosting
Ok so what would make my boost creep back down after i peak at 5k rpm and still have 3k to go
over boosting
too small of a turbo, too big of a wastegate, or boost leak, or faulty wastegate.Redline;292966 wrote:Ok so what would make my boost creep back down after i peak at 5k rpm and still have 3k to go
Redline
over boosting
Its probley the turbo its the only cheap thing of my build its a ebay and i wasw running 16psi, it would hit it fast then creep back down to like 12 or 14
Boosted_da
over boosting
i would have to agree with rick you probably need a bigger turborickles8099;292998 wrote:too small of a turbo, too big of a wastegate, or boost leak, or faulty wastegate.
crimsoncivic
over boosting
Lol isn't that always the answer :rock:Boosted_da;293076 wrote: you probably need a bigger turbo
