d15 modding questions
boostjunkie
Too bad the y8 mani wouldnt work i have one of them laying around but thats for obd2. Would any of the plugs and clips off a z6 or y8 work? Or would i only be able to use ones off a obdo car?
Edison Carasio
boostjunkie
Can i use obd1 injectors and clips if i am using the resistor box? Im gunna be using d16z6 intake and also got a whole underhood d16z6 harness for some plugs and injector/clips.
