98 honda accord...
this is my uncles car and im having problems with it
we had codes for misfires, egr and one other
was p0301, 302 and 304
also p1399
now only one left is p0302
compressor check all good
new plus wires cap rotor and wires.
new injetor on #2
when u pull number 2 injector power plug off no change in the motor..
also new egr and pulled the intake and cleaned out all the carbon...
what am i missing here??
it has a miss at idel but runs great other wise
cylinder misfire help
95_gsrfodo
4 Doors = More Whores
95_gsrfodo
Pull the #2 plug and wire. Keep the plug in the wire and touch the plug to a ground. Do you see a good solid spark?
95_gsrfodo
yepp didnt do it that wa i have the spark tester that looks like a spark plus u clamp to a ground.. but ya good spark
95_gsrfodo
ok quick update rechecked the compression myself
cylinder 134 have 160 and 2 is only at 10
added traany fluid into the cylinder and still only at 10 seems it may have a bad valve??
95_gsrfodo
gonna try nd check it tommorrow... if it is im guessing bend valve? car has 270,XXX miles runs great other then at idel.. and idle the car has a bigg missWaffles;291627 wrote:Pull the vc and see if the spring looks more compressed than the others.
but when driving u cannot tell theres any problems at all..
his problem is he cant pass emmission with it like this
