b16 swap please help
96eg2
Post by 96eg2 »
im looking into putting my b16 out of the 96 del sol vtec i had into a d series del sol if i cant find one with a b16 already in it what all do i need. i have the motor trans, wiring harness, ecu, shift link basically everything. But the wiring harness was a pain in the ass to pull out of my old car so im thinging its going to be even more of a pain installing it just wandering if there is and easier way?
Post by Clayton »
96eg2;289105 wrote:im looking into putting my b16 out of the 96 del sol vtec i had into a d series del sol if i cant find one with a b16 already in it what all do i need. i have the motor trans, wiring harness, ecu, shift link basically everything. But the wiring harness was a pain in the ass to pull out of my old car so im thinging its going to be even more of a pain installing it just wandering if there is and easier way?
an easier way than what? not running a wiring harness?
If I am not mistaken, a b16 goes into a del sol with the stock harness
ymisoqt
Post by ymisoqt »
Waffles;289109 wrote:If I am not mistaken, a b16 goes into a del sol with the stock harness
I think so. And axles, ecu, shift linkage, alternator and mounts. But don't quote me on that.
94 Legend
94 Del Slo
90 S13 <3
92_luder
Post by 92_luder »
if it came out of a del sol it should go right in...i dont see why not......but like she said dont quote me
Post by HardCore97 »
ymisoqt;289110 wrote:I think so. And axles, ecu, shift linkage, alternator and mounts. But don't quote me on that.
92_luder;289113 wrote:if it came out of a del sol it should go right in...i dont see why not......but like she said dont quote me
:boxer:
Racecore.com
gcef89
Post by gcef89 »
everyones post seems legit to me, but always do research
bks
Post by bks »
the only thing i can see you having an issue with is a del sol vtec (b16) has a knock sensor and its wired into the cabin side as well as the engine side. so youd have to run a wire from the shock tower plug to your ECU if you used the usdm p30 ecu.
aside from that, i dont see any issues with the swap at all. should be fairly easy.
onecam12sec
Post by onecam12sec »
dont forget that u have to use the b16 t-bracket. and do some research, because they might share the same underdash harness as the b16 sols. if that makes sense
I'm gon hurt some feelin's this summer
bks
Post by bks »
a B16 bracket? the t-brackets on all 94+ B series are the same.
whats the under dash harness have to do with an engine swap?
