Crank pulley bolt
92_luder
Crank pulley bolt
Post by 92_luder »
having a hard time gettin the crank pulley bolt off, the impact gun is jus slowly turnin the engine...
Crank pulley bolt
Get a strap wrench to hold the crank pulley.
If you still have issues, use heat directly to the crank bolt
Finally if its still stuck get a stronger impact.
bks
Crank pulley bolt
Post by bks »
Ive never had any luck with strap wrenches on stuck pulley bolts. this lil guy has always been reliable though...
http://ecx.images-amazon.com/images/I/3 ... AA300_.jpg
[ame="http://www.amazon.com/Powerbuilt-648796 ... B0000TMLWQ"]Amazon.com: Powerbuilt 648796 Honda Crankcase Pulley Removal Tool: Home Improvement[/ame]
delslo
Crank pulley bolt
Post by delslo »
I just took mine off with an impact last week. Lower one tire to the ground and put it in gear. Created enough resistance for me to get it free. I've recently heard of someone holding the brakes down for you too.
twkdcd595
Crank pulley bolt
Post by twkdcd595 »
Put the car in 5th gear... hand someone stand on the brakes hard. Use a big breaker bar and pop it loose.
That is how I have done it the last couple times. Worked even on the last time just a week or so ago and it was on tight enough an electric impact or a cordless would not work. Air probably would have but I do not have air at my house.
muha22752
Crank pulley bolt
Post by muha22752 »
Dam, I am having trouble with this too, but the motor is not in my car. guess I need a better impact.
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
01luda
Crank pulley bolt
Post by 01luda »
brake out the tourch. had problem on an old f22
muha22752;289794 wrote:Dam, I am having trouble with this too, but the motor is not in my car. guess I need a better impact.
Edison Carasio
Crank pulley bolt
Post by Edison Carasio »
I've seen Rickles use one of these monsters on it. Takes em ALL off in seconds.
ymisoqt
Crank pulley bolt
Post by ymisoqt »
damn ^
I've never had luck getting a crank pulley off with air. Twice I had a compressor brought to my house to use and ended up getting it with a "breaker bar" aka the handle off of my jack over a socket wrench and a screwdriver in the flywheel to hold the motor from turning.
94 Legend
94 Del Slo
90 S13 <3
Crank pulley bolt
Usually I can get it with a combo of liquid wrench, heat, a strap wrench, and a fresh battery on the impact.
