swap help
swap help
you can use the harness from your ex, you will have a couple extra plugs though, but that just means you can throw a vtec head on it later and the vtec plugs will be there. you may have to lengthen a couple plugs, i dont remember, but regardless it will far easier to just use your original harness and make sure everything is plugged up to its proper sensor on the b20
Racecore.com
Racecore.com
swap help
It sounds like you have an OBD0/OBD1 alternator on there. You need to use a '97-'01 CR-V alternator to make everything plug and play. Or do a little wiring.
http://ff-squad.com/wp/?p=425
You'll need a '97-'98 Honda CR-V distributor. A 10-pin '96-'01 Acura Integra LS/RS/GS (B18B1) distributor will work too. The '99-'00 Civic Si distributor will not bolt on. An OBD1 B20 or B18 distributor will work as well with a little wiring or an adapter harness.
http://ff-squad.com/tech/wiring/obd1-2dizzywiring.jpg
http://www.rywire.com/catalog/obd2-10pi ... 0b6734ee89
