oil in spark plugs
gcef89
oil in spark plugs
ok my gf's crx is getting oil into where the spark plugs go i replaced all the gaskets to the valve cover and got new plugs and wires and still oil is getting into it was wondering if anybody else knows what i can be? stock d15b2
95_gsrfodo
oil in spark plugs
bad valve cover gasket the ones around the spark plug tubes..gcef89;275301 wrote:ok my gf's crx is getting oil into where the spark plugs go i replaced all the gaskets to the valve cover and got new plugs and wires and still oil is getting into it was wondering if anybody else knows what i can be? stock d15b2
4 Doors = More Whores
Cman46290
oil in spark plugs
definitely spark plug tube seals
1997 Acura Integra GSR
Intake
Header
OBX Exhaust
Rota Boost Wheels
ALL MAINTENANCE
Intake
Header
OBX Exhaust
Rota Boost Wheels
ALL MAINTENANCE
fry
oil in spark plugs
or the tubes that are pressed into the head have backed off a little. but more than likely the grommets
gcef89
oil in spark plugs
thanks guy's i guess ill be fixing that this weekend i though it would be this but wanted to see what everyone else though to!
Uncle_Willie
oil in spark plugs
I would suggest buying oem seals, i got some junk ass ones from oreillys that i couldnt even fit around the tubes.
1992 Civic Dx Sedan l D15B Vtec l Tucked l lowered l Fit Sport Wheels
gcef89
oil in spark plugs
thanks for the input is this hard to do?Uncle_Willie;275402 wrote:I would suggest buying oem seals, i got some junk ass ones from oreillys that i couldnt even fit around the tubes.
95_gsrfodo
oil in spark plugs
if u can pull the valve cover the tube gaskets are right there as well.. old one may be hard and brittle.. pull them up and replace them install new ones...gcef89;275406 wrote:thanks for the input is this hard to do?
and all set install new valve cover gasket as well i would say get oem honda gasket as well
Uncle_Willie
oil in spark plugs
Not really. Mine were a pain in the ass to get out. Just make sure you put some oil around the outside/inside of the seals. Thatll make them easier to get in the valve cover and then you can slip them around the tubes easier.gcef89;275406 wrote:thanks for the input is this hard to do?
gcef89
oil in spark plugs
are you guys tlking about the upper tube seals or lower tube seals? and if lower do you have to mess with timing when taking of the rocker assembly?
