d15b8 mini me
91beatuphatch
d15b8 mini me
Post by 91beatuphatch »
okay im tired of my 70 hp turd under my hood. im thnkin on mini me'ing it. my question is. ive heard that certain years came with 4 valve reliefs and certain ones came with 2. ie: 8 valve engine. i cant find anything on what years had what. so id like to know before tearing everything down for nothing. any help?
d15b8 mini me
Post by 90CivicEx »
Pull the valve cover
Uncle_Willie
d15b8 mini me
Post by Uncle_Willie »
Sorry if I missed something, but if your wanting to do a mini me swap what does the current amount of valves have to do anything?
1992 Civic Dx Sedan
l D15B Vtec l Tucked l lowered l Fit Sport Wheels
Andrew
d15b8 mini me
Post by Andrew »
Uncle_Willie;272071 wrote:Sorry if I missed something, but if your wanting to do a mini me swap what does the current amount of valves have to do anything?
Some b8's came with pistons that didn't have valve reliefs for 16 valves IIRC
Edit: say his only had reliefs for 8 valves, a 16 valve head couldn't be used because the valves would hit the piston, causing damage to the head and pistons.
Uncle_Willie
d15b8 mini me
Andrew;272073 wrote:Some b8's came with pistons that didn't have valve reliefs for 16 valves IIRC
I Gotcha, thanks.
From what reading ive done in the last 5 minutes to my understanding they had an 8 valve b8 and a 16 valve b8 but both engines came with pistons with 16 valve reliefs. Nobody seems to be 100% sure though. I would buy everything and have it ready, then pull the head and check for sure. If it has 16 do it, if it only has 8 then I guess you can chalk it up as a failed experiment lol
Edit: What year is your car BTW?
1992 Civic Dx Sedan
d15b8 mini me
Post by 90CivicEx »
Uncle_Willie;272074 wrote:I Gotcha, thanks.
Which is why I said pull the valve cover lol, 16 valves there you got the reliefs if not scrap that shit buy an actual d15b, d16z6, d16y8 whatever get your conversion harness on and ecu and goto town.
opntrk86
d15b8 mini me
Post by opntrk86 »
Only way to know for sure is to pull the head. The b8 that was originally in my 94 cx was an 8-valve but had 16 reliefs.
d15b8 mini me
Post by 90CivicEx »
opntrk86;272076 wrote:Only way to know for sure is to pull the head. The b8 that was originally in my 94 cx was an 8-valve but had 16 reliefs.
No pull the valve cover there will show if its 16v why yank the head if there isn't 4 reliefs it wouldn't have 16v and be eatting 8 valves and 4 pistons for lunch lol
91beatuphatch
d15b8 mini me
no its the pistons corey. all b8's are 8 valve just like the crx hf. but certain years had 16 valve pistons with an 8 valve head. the engine came out of a 95 aparently.
Uncle_Willie
d15b8 mini me
91beatuphatch;272086 wrote:no its the pistons corey. all b8's are 8 valve just like the crx hf. but certain years had 16 valve pistons with an 8 valve head. the engine came out of a 95 aparently.
Run the VIN to check the year, i read somewhere last night that the 92-93 had 8 and the 94-95 had 16.
1992 Civic Dx Sedan
