da wont start please help
91TEGDA
Post by 91TEGDA »
i have nothing but problems with this car since the day i picked it up. i have replaced wires, plugs, coil pack, rotor, ingnition control module, and the fuel pump and the car still wont start. i used to be able to hear the fuel pump prime but now nothin even with the new fuel pump.:smashfreakB:. could someone please help
gcef89
Post by gcef89 »
did u check ur fuses or main relay? im having the same trouble!
Main relay.
grounding issues
Ecu
If you pull the plugs and crank the engine does fuel spray out?
Try tapping on the main relay with the key on, engine off. Then try and start it.
91TEGDA
Post by 91TEGDA »
Waffles;271007 wrote:Main relay.
grounding issues
Ecu
havent got that far spent most of the day droping the gas tank and replacing the fuel pump. and where is the main relay located? i have had a replacement for a while now but cant find it.
Post by Phate »
91TEGDA;271015 wrote:havent got that far spent most of the day droping the gas tank and replacing the fuel pump. and where is the main relay located? i have had a replacement for a while now but cant find it.
http://www.tegger.com/hondafaq/mainrelay.html
gcef89
Post by gcef89 »
it sits tucked under ur change compartment up on ur dash
91TEGDA
Post by 91TEGDA »
i assume this is a dif. relay than the main ignition relay? because thats what i have and is def not the same relay that is directly behind my coin box.
91beatuphatch
Post by 91beatuphatch »
91TEGDA;271699 wrote:i assume this is a dif. relay than the main ignition relay? because thats what i have and is def not the same relay that is directly behind my coin box.
there are 2 directly behind the coin tray. its the larger of the two. simple. click on the link above thats what i did.
91TEGDA
Post by 91TEGDA »
finaly got around to messing with my car again, sprayed starting fluid into the intake and she started right up and stayed running. when i killed it and go to crank it over with out starting fluid it started. it does this a few times and then decides it doesnt want to start again. left it over the weekend went to start it this morning with no ether and it started up no problem and has had no problems all day.
