anyone mated f22b block to h22a1 head?
exnissanguy
Im thinking this might be the route I go for the ef hatch i plan on building. Seems mildly straightforward. Just seeing if anyone on here has one or thoughts on it. Tossing this or a h22a1
92_luder
from what i understand gettin a h22 head on any f series block is not impossible but takes alot of modifications......while the h23 head bolts right onto the f22 bottom end, which alot of guys use for turbo build since the f series didnt come with the frm sleeves...
exnissanguy
yea the mods dont look too crazy, some hondabond here and there to close up some coolant jackets. I plan on running a mildly stout boosted setup on the motor hence, the f22 block92_luder;269368 wrote:from what i understand gettin a h22 head on any f series block is not impossible but takes alot of modifications......while the h23 head bolts right onto the f22 bottom end, which alot of guys use for turbo build since the f series didnt come with the frm sleeves...
95_gsrfodo
4 Doors = More Whores
92_luder
hey gud luck man, id love to see the frankenstein put together.....i thought about it myself but its out of my reach
92_luder
jus stock it wont do much.....these builds high comp, or boosted are super torquey tho....
LolitaPierce
i ran this setup for a while years ago.. ran good til i swapped it
