car won't start
civicex
car won't start
Post by civicex »
well i went to pick up my dog from the groomer on my way back i turned out of the parking lot and it kind of puttered then died it rolled for a while. sometimes when i go around turns it would do it too but never would die. i'm at a loss please help. it has gas and the full pump kicks on but i don't wanna rule the fuel pump out.
it's a 94 civic ex.
oh and the cel is not on.
PSN: DumbRands
civicex
car won't start
Post by civicex »
civicex;267586 wrote:well i went to pick up my dog from the groomer on my way back i turned out of the parking lot and it kind of puttered then died it rolled for a while. sometimes when i go around turns it would do it too but never would die. i'm at a loss please help. it has gas and the full pump kicks on but i don't wanna rule the fuel pump out.
it's a 94 civic ex.
bump
PSN: DumbRands
car won't start
Post by HardCore97 »
Is it getting spark?
Racecore.com
civicex
car won't start
Post by civicex »
HardCore97;267613 wrote:Is it getting spark?
yeah but i don't think i have any fuel pressure.
PSN: DumbRands
civicex
car won't start
Post by civicex »
civicex;267616 wrote:yeah but i don't think i have any fuel pressure.
bump
PSN: DumbRands
car won't start
civicex;267659 wrote:bump
Did you check your fuel pressure? :tard:
Smiling Shadow
car won't start
Post by Smiling Shadow »
if you have fuel pressure and spark how old is your timing belt any chance you skipped a tooth?
civicex
car won't start
Post by civicex »
JustRob;267661 wrote:Did you check your fuel pressure? :tard:
if i knew how i would so no lol
edit:
i'm pretty sure it's ignition coil.
PSN: DumbRands
Smiling Shadow
car won't start
its not the best way but if your on the side of the road still after cranking take the return fuel line off the the rail if there is a good amount of fuel there chances are you should have enough pressure to start
Smiling Shadow
car won't start
i had a coil do the same damn thing to me now i ride around with a spare in my glove box
