ef help
gcef89
ef help
Post by gcef89 »
so i swapped in a b18a1 into my 90 civic si everything is working other than my 02 sensor i got the 4 wire 02 sensor and now i have no clue what wires go to it anybody know? or if you need more info let me know
Redline
ef help
Post by Redline »
i am sure you only need the 4 wire if you do the obd1 swap, but i may be wrong
More power coming soon
ef help
Post by stolle »
if your still obd0 use your old one wire o2, not the 4 wire.
Team NOCO Crew Member #2
gcef89
ef help
Post by gcef89 »
well im obd1 now thats why i needed the 4 wire 02 sensor
ef help
gcef89;265813 wrote:well im obd1 now thats why i needed the 4 wire 02 sensor
What did you use to convert to obd1? If you used a rywire conversion harness then it should have came with wires to splice a 4 wire o2 too
gcef89
ef help
Post by gcef89 »
i have the wires but i have no pigtail for my 02 sensor so i have no clue what color wires go where?
i have these color wires left over
pink
brown
two blacks
blue
red
yellow
orange
white
yellow,orange,and white tested as hot wires
gcef89
ef help
Post by gcef89 »
does anyone know what wires i need for my 02 sensor how many positives or negatives i need?
ef help
This should be able to help you figure out which wires go where. Next time buy a quality conversion harness so you don't have this problem.
http://www.ff-squad.com/technet/wiring.obd1.htm
gcef89
ef help
Post by gcef89 »
thanks that helps out a lot!
