so i have to buy a new distributor...adn i keep hearing bout advancing the timing to get power...and there are ways to advance it to get low and and diff ways to adjust it to get high end(more so my interest)...
is this a good idea.....?
Advancing timing
92_luder
Advancing timing
fry
92_luder
Advancing timing
i like a str8 answer....but what happens if you do and it fucks up??
Advancing timing
You dont advance timing by just turning your distributor. It needs to be timed correctly so your car runs right.92_luder;261729 wrote:i like a str8 answer....but what happens if you do and it fucks up??
You can advance cam timing with some adjustable cam gears, and some dyno tuning. Wouldnt waste your time on a stock engine, with stock compression, and stock cams.
92_luder
Advancing timing
good reason thanks guysPhate;261733 wrote:You dont advance timing by just turning your distributor. It needs to be timed correctly so your car runs right.
fry
Advancing timing
Because the gains are absolutely minuscule. If you want a fast car buy an ls1 or any other car that isn't a Honda
