please help! whats this on intake?
sirricealot
So my idle sucks when I start it up, fluctuates. But when warms up stays like 900-1100. I'm fine with that but why is it when it eight after I start? Air bubbles? Got a new tps but haven't taken tb off yet. Unplug tps and usually idle fluctuations go asay
xbxlive: sirricealot07
ps3: sirricealot7
David Runyon
ps3: sirricealot7
David Runyon
I'm guessing you didn't do what we said...
sirricealot
You mean setting the idle with jumper unplugging and doing it with and without accessories? I just adjusted the fitv cleaned the iac and the guy I'd my idle screw. That picture illustration is what I need to do also?
ps3: sirricealot7
David Runyon
ps3: sirricealot7
David Runyon
JustRob;261500 wrote:This should help you a little bit. Basically a more detailed guide to stolle's previous post.
Check that all the vacuum lines match this diagram and that they are all in good shape.
The more detailed guide to properly setting the idle speed.
Based on what you've posted, this seem like it would fix your issue. If not, post the results and I'll get you more info from there.
do this and nothing else, if you dont do it correctly it will never be right.
sirricealot
Ok I'll try this weekend. Thanksstolle;261742 wrote:do this and nothing else, if you dont do it correctly it will never be right.
ps3: sirricealot7
David Runyon
ps3: sirricealot7
David Runyon
Yep. I don't know how I could have made that any clearer. You must do that so I can help you figure out if there is an issue beyond just needing some things cleaned and adjusted.sirricealot;261726 wrote:You mean setting the idle with jumper unplugging and doing it with and without accessories? I just adjusted the fitv cleaned the iac and the guy I'd my idle screw. That picture illustration is what I need to do also?
sirricealot
[ame="http://www.youtube.com/watch?v=pvi8AEpBo1Y"]YouTube - After the reset and tweak[/ame]
ps3: sirricealot7
David Runyon
ps3: sirricealot7
David Runyon
