please help! whats this on intake?
sirricealot
Post by sirricealot »
what is the following things on my intake/manifold. I noticed it a few months ago and didnt think anything of it until now. may solve my random idle issue....
the red is the plastic piece that has no hoses and the other color beats me...
please any help is appreciated.
thanks!
UPDATE: heres the link to my NEW idle issue. after cleaning the iac valve it does this. iphones rule!
[ame="http://www.youtube.com/watch?v=_dSgMQsfqTE"]http://www.youtube.com/watch?v=_dSgMQsfqTE[/ame]
xbxlive: sirricealot07
ps3: sirricealot7
David Runyon
Post by Phate »
That should go from the breather outlet on your valve cover to a port on the intake tube.
Probably isnt hooked up because of your jdm tyte ebay intake.
sirricealot
the red hose and the hose above that black plastic piece in question is hooked up to the cold air intank. im cleaning my IAC valve as we speak.
Phate;261388 wrote:That should go from the breather outlet on your valve cover to a port on the intake tube.
ps3: sirricealot7
David Runyon
Post by Phate »
That works too.
sirricealot
cleaned it and now it wont start.
wtfffff.
is it bc its not all the way dry or what?
kinda tried turning over but now all i get is clicking.
Phate;261392 wrote:That works too.
ps3: sirricealot7
David Runyon
Post by Phate »
Whats your idle issue?
sirricealot
it was idling randomly between like 750-1750 rpm. the iac was pretty dirty, and cleaned it. but now nothing starts...
Phate;261394 wrote:Whats your idle issue?
ps3: sirricealot7
David Runyon
sirricealot
ok so the battery was just low.
but now it smokes(good thing i hope) and idle is still fuzzy.
750-1500 rpm, then like 300-1200
ps3: sirricealot7
David Runyon
ymisoqt
Post by ymisoqt »
Make sure you don't have any air in your cooling system or vacuum leaks.
94 Legend
94 Del Slo
90 S13 <3
Post by Phate »
Got the video you emailed. Good quality too. Put it on youtube and link it here.
I had a similar issue with one of my old cars that ended up being the fast idle thermo valve. Should be on the back of the manifold.
Inside it is a plastic disc that you should need to tighten down and that fixed my surging idle.
Also you should look for any vacuum leaks.
