Problem 1
When my car warms up I come to a complete stop and SOMETIMES it makes a popping noise and I can feel it in my dead pedal. Taking off from a stop in first I hear and feel the noise again, and sometimes shifting from 1st to second I get the same thing. Just now it has started making the noise going over bumps at low speeds it does the same thing.
I jacked my car up and checked to see if I had play in my ball joints and no play whatsoever. I just replaced my driver side axle and outer tie rod about a month ago and it didn't fix the popping noise. The more I drive the car the more often it pops.
Problem 2
Every time I make a slight continuous curve whether it's on the highway or from a stop it feels like something pops loose and the whole back end shifts over. Tom was behind me on the highway not too long ago and he could see it hop over. As soon as that happens my ATTS light kicks on and it won't do it again until I turn my car off and back on.
Any suggestions would be helpful. Thanks so much
Popping noise and odd back end shift.
99PreludeSh
Sounds like your car is falling apart!! Is there mainteance that is sposed to be done with the ATTS bs?
99PreludeSh
yeah fluid change but that's about it. As soon as I get the unit from Sharpie Im going to change that fluid and replace it with the one I have now.Phate;228202 wrote:Sounds like your car is falling apart!! Is there mainteance that is sposed to be done with the ATTS bs?
crx08
you should get it from him asap! and get it fixed yo!99PreludeSh;228204 wrote:yeah fluid change but that's about it. As soon as I get the unit from Sharpie Im going to change that fluid and replace it with the one I have now.
stl-imports.com/forums
99PreludeSh
I've been trying lolcrx08;228240 wrote:you should get it from him asap! and get it fixed yo!
muha22752
give me a call and we can take a look
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
W.K.D
99PreludeSh
look at what? I have looked at it all but nothing looks out of the ordinary, you wanna climb under the car while I'm driving be my guest!muha22752;228304 wrote:give me a call and we can take a look
muha22752
wheres it coming from
umadbro?
W.K.D
W.K.D
99PreludeSh
my guess would be the suspension since I can feel it in my feet. Someone mentioned that they had the same exact problem and it was a wheel bearing so I'm going to replace it and see if it still does it.muha22752;228427 wrote:wheres it coming from
