Sea Foam treatment?
ZenkiS14
Sea Foam treatment?
Post by ZenkiS14 »
Any of you guys ever try doing the sea foam treatment? Im having gas milege issues and maybe a stuck injector, I was just wondering what the best way to do it on these motors are...
Sea Foam treatment?
Post by HardCore97 »
i just do it like the instructions say. 1/3 in gas, 1/3 in oil, and 1/3 through the brake booster line. some people dont like putting it in the oil though so thats up to you
Racecore.com
luvmyhondas
Sea Foam treatment?
Post by luvmyhondas »
i had good luck with it unsticking some rings in a CRX once. definitely couldn't hurt.
AKA audioguru76
79 Hondas and counting!
91TEGDA
Sea Foam treatment?
Post by 91TEGDA »
HardCore97;257281 wrote:i just do it like the instructions say. 1/3 in gas, 1/3 in oil, and 1/3 through the brake booster line. some people dont like putting it in the oil though so thats up to you
i have heard that you need to do an oil change about 15 min after you put it in the oil tho.
JDM EM1
Sea Foam treatment?
Post by JDM EM1 »
91TEGDA;257287 wrote:i have heard that you need to do an oil change about 15 min after you put it in the oil tho.
this is true.
I'd def do it right before your going to change your oil. I've used sea foam plenty of times. gas/oil/booster line. make sure you read the instructions & amount that is needed.
when doing it in booster line, do it slowly so the car doesn't die out on u, then once u poured the amount needed I always held throttle around 2k-3k for a few ( a lot of smoke will come out) U can drive it around if you'd like or just let it idle for 15-20mins, then change your oil & filter.
ZenkiS14
Sea Foam treatment?
Post by ZenkiS14 »
Well I bought some BG 44K stuff through my work, supposed to be alot nicer than SeaFoam, gonna throw that in today with a full tank. So I'm gonna run that stuff through the fuel system this week, and then probably do some seafoam through the intake system sometime this week when I do an Oil change.
Hope it helps!
