can anyone tell me this?
civicex
Post by civicex »
My speedometer doesn't always work could it be one of the speed sensors and, my odometer doesn't seem to always work either any ideas?
I have a 94 civic ex.
Uncle_Willie
Post by Uncle_Willie »
Pretty common problem, i had it with my 95 ex. I just kind of shook on my speed sensor and it fixed the problem lol....You could try that and take the plug off the speed sensor and clean it, its probably just losing connection.
1992 Civic Dx Sedan
l D15B Vtec l Tucked l lowered l Fit Sport Wheels
tommygun89hb
Post by tommygun89hb »
+1 to the loose connection usualy if the speeomter does not work but the rest of the cluster lights up it is a voltage problem to the speed sensor.
A nother rule of thumb is when you go to fix something and it doesnt work right after words go back to where you put your dick skinners last LOL
civicex
Post by civicex »
Uncle_Willie;255890 wrote:Pretty common problem, i had it with my 95 ex. I just kind of shook on my speed sensor and it fixed the problem lol....You could try that and take the plug off the speed sensor and clean it, its probably just losing connection.
Thanks I'll try that.
PSN: DumbRands
probabley a bad cluster... rob had this issue recently with his hatchback and swapped clusters and it fixed the issue
opntrk86
Post by opntrk86 »
x2 on this
I have seen a few speed sensor plugs corrode bad enough to cause intermittent connection problems. It's the three terminal plug on the top side of the tranny.
Post by mike93hatch »
THE most common problem is a bad cluster...youll have to get a new cluster.
