You're right. I forgot to add that in there.opntrk86;256042 wrote:If I remember correctly, I think the EX autos still had the 3 wire IACV.
Did you auto to manual swap your shell?
Obd2a to Obd1 throwing codes and bouncing Idle
Uncle_Willie
Didnt get to clean the iacv or the fitv, but i would check for vacuum leaks and then try that.civicex;256009 wrote:if you figure it out, let me know i'm having the same issue.
It was a manual shell, I think I have it fixed though....turned out to be a really small vacuum line that wasnt on lol...I put it on and it ran perfect. Ive gotta run the codes still to see if its still throwing any but i took it out and drove it. It runs and drives perfect now. And hopefully that will help my gas mileage lol.JustRob;256050 wrote:You're right. I forgot to add that in there.
1992 Civic Dx Sedan l D15B Vtec l Tucked l lowered l Fit Sport Wheels
