No start!
coupe95
No start!
Post by coupe95 »
b16a2 swap in 95 coupe. solid engine light, no spark or fuel.
changed pgmfi relay. diff dizzy. and tryed different ecu. and all the wiring i did is connected right. at dead end any ideas?? thanx
No start!
what is the check engine light?
No start!
Post by Gunmetal Si »
engine harness ground on the thermo housing? is it tight. is the fuel pump priming?is the ecu pluged in?
No start!
Post by 5thgen »
coupe95;244622 wrote:b16a2 swap in 95 coupe. solid engine light, no spark or fuel.
Is it a solid light when you have the jumper in to test the code?
tommygun89hb
No start!
Post by tommygun89hb »
fuse 14 (alt sig) under the dash its a 10a fuse take it out dont test it or even look at it. Put a brand new one in it.
This same thing happened to me on my ef a couple of years back i tore my hair out trying to fix it.
turns out the fuse had a small hairline crack in it so minute it would even test good. but once you went to start it then it would expand and break the connection.
Took it out replaced it and started right up.
A tell tell sign is if when you turn on your car then these lights would be on
Oil light, Batt light, check engine light.
Try this out
coupe95
No start!
Post by coupe95 »
soon after i posted that i went out pokin around under the dash and realized there was a blown fuse i dont know how i missed it. ACG (s) replaced it turned key heard fuel pump kick on then started right up. any one know what this fuse does. cant find much about it.
tommygun89hb
No start!
it should be the alt signal fuse AKA fuse 14 it tells the ecu that a alternator is present and it is ok to start the car basicly. Its just one of many in the PMFI fuel system. Thats about all i know.
coupe95
No start!
Post by coupe95 »
cause of blown fuse was exposed wire that grounded out on alt case from the conversion i did.
