oil problem
stevescrx
oil problem
Post by stevescrx »
so i pulled one of my spark plug wires out and it had oil all over it and there was a puddle of oil around the spark plug so i cleaned it out and changed the valvecover gasket and all of the o rings and it is still doing it anyone have any ideas it is just one cylinder and its the last one on the drivers side..
oil problem
Post by Clayton »
stevescrx;240820 wrote:so i pulled one of my spark plug wires out and it had oil all over it and there was a puddle of oil around the spark plug so i cleaned it out and changed the valvecover gasket and all of the o rings and it is still doing it anyone have any ideas it is just one cylinder and its the last one on the drivers side..
check to make sure you didnt double gasket the spark plug o ring
stevescrx
oil problem
Post by stevescrx »
i pulled them all off and put it back on and i think oil drained into my cylinder and now the car wont start... how fucked am i lol
oil problem
Post by HardCore97 »
a little oil draining into a cylinder wouldnt cause it not to start.
Racecore.com
stevescrx
oil problem
Post by stevescrx »
lol wtf then cuz now it wont start... lol gotta love the little things
Lynxs1981
oil problem
Post by Lynxs1981 »
Check that plug and make sure it's not fouled with the oil. Make sure the top of the top of the tube is smooth where the seal sets. You said the "o-rings," do you mean tube seals?
oil problem
even if it was fouled it should still start up. got any CELS?
Racecore.com
andyjt
oil problem
Post by andyjt »
Did you change the O-rings between the Cylinder head and Cam camps for the spark plug tubes?
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
