Got a question hope someone can answer.
When looking at my motor the whole block has oil on it. I pulled the plug wires and there is oil in there too.
Is the valve cover not sealed properly? Or is it something else?
Oil leak?
02Type-S
Oil leak?
Sounds like the rear main seal, and the valve cover gasket/plug grommets.
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
02Type-S
Oil leak?
seal between transmission and blockGAWear;238645 wrote:So valve cover gasket and plug grommets I get.....what would the rear main seal be?
Bare with me.....Not messed with motors ever really
2002 Acura TL-S
2002 Acura TL-S
Oil leak?
there is no seal between the transmission and the block. also, if the rear main were leaking, oil would be located under the seal and inside the transmission bellhousing. not all around the block.02Type-S;238667 wrote:seal between transmission and block
best way that i have found to troublshoot on where an oil leak is coming from is to start at the bottom of the engine and work your way up. where the trail of oil stops is where the leak is coming from.
