I am replacing my exhaust, when I went to take the header out I pulled the wires from the housing, which they can plug back into no problem. My problem is I am unsure on which order they go in. I looked at the other 02 sensor for color order, plugged it in that order.
My question is, is the color order the same on both of the sensors or is there a different pattern for each sensor?
This is for an Integra if it makes a difference, I looked it up, didn't really find anything helpful.
Thanks,
James
O2 sensors help. Simple question!
J.M.P
-2010 Honda Fit
-2000 EBP Civic SI
crx08
plug and play? just try to switch the wires around until you get it right lol
stl-imports.com/forums
J.M.P
That is what I am going to do if I don't get a definite answer.crx08;233926 wrote:plug and play? just try to switch the wires around until you get it right lol
I did just go down to the garage and turn the key over and the check engine light did not stay on, so I suppose that is a good thing. I will know for sure tomorrow when I get it all bolted up and running.
-2010 Honda Fit
-2000 EBP Civic SI
J.M.P
Well I got it all bolted up and its all ok. But the check engine light is on. I guess I will mess with the 02 sensor some more till its ok, or just take it somewhere with a lift. Easier than crawling under the car, haha.
-2010 Honda Fit
-2000 EBP Civic SI
J.M.P
Also one more thing I should mention. My integra is a LS, the exhaust is made for a gsr. So the header is shorter, making the cat longer. So both of the 02 sensors go into the cat instead of one into the header and one in the cat like on the LS exhaust. Will this make the CEL come on in this case as well?
-2010 Honda Fit
-2000 EBP Civic SI
J.M.P
