Teg won't start need help
Jhobbs85
Post by Jhobbs85 »
Driving downshift 3-2 car died now won't start told could be couple things.
So tried three pieces of advice changed main relay,fuel pump,and fuel filter have no spark or fuel pressure. A member of another forum had same problem replaced same things and shop told him distributor went bad. Could this be my problem would it explain having no spark fuel pressure please help.
crx08
Post by crx08 »
how many miles on your integra? ignition switch?
stl-imports.com/forums
Post by Gunmetal Si »
spark yes but not fuel. check the wiring at the ecu. or ecu itself.
Jhobbs85
Post by Jhobbs85 »
No spark or fuel pressure
crx08
Post by crx08 »
what year integra? any modifications done to it?
Jhobbs85
Post by Jhobbs85 »
95 yeah but cpl other ppl on here no more about the modifications and all fuses are good
crx08
Post by crx08 »
what kind of mods? anything that has to do with the wiring?
Jhobbs85
Post by Jhobbs85 »
It's been tucked
see if anybody has a dizzy you can try to see if thats the issue
probley a bad ignitor
gsrauto98
Post by gsrauto98 »
N2HIFI;229135 wrote:see if anybody has a dizzy you can try to see if thats the issue
asked him about the dizzy, the only person close to him is 30miles away and his is a 00 gsr, he has 95? so that wont work.
He said he's not getting any fuel pressure either...
