Spark Plugs
BlueDevil
Spark Plugs
Post by BlueDevil »
I'm currently using NGK standard spark plugs. These have been working great and I haven't had a single issue with them yet. My car is running a small greddy turbo (T517Z) and has a hondata installed by Lowe Performance. LP ran the car on the dyno with the current spark plugs in it. Before the hondata was installed, I used to run NGK Iridiums, but they had a tendency to burn at too high a temp and blow, so I want to avoid using Iridiums. Does any one know where I can find NGK standard spark plugs or a sutable replacement? Advance Autoparts, Autozone, and O'Reilly Autoparts no longer carry standard NGK plugs.
Spark Plugs
CarQuest is where I got my NGK plugs from. I perfer NGK BKR7-E plugs on my turbo cars gapped .005" tighter then OEM spec.
J_Jay_B
Spark Plugs
Post by J_Jay_B »
im sure NGK has a website.
YES
the individuality of your car is frowned upon... welcome to the honda community
LOLZ
Bwill9886
Spark Plugs
Post by Bwill9886 »
Obi Wan;228162 wrote:I perfer NGK BKR7-E plugs on my turbo cars.
This.
Solid plugs and they are CHEAP.
v-tecivic
Spark Plugs
Post by v-tecivic »
Bwill9886;228173 wrote:This.
+1. these are what i'll be using with my setup.
97 civic ex turbo
13.1@112
Spark Plugs
Post by 5thgen »
i've been hearing good things about ngk 9s
Spark Plugs
Post by mike93hatch »
BlueDevil;228159 wrote:I'm currently using NGK standard spark plugs. These have been working great and I haven't had a single issue with them yet. My car is running a small greddy turbo (T517Z) and has a hondata installed by Lowe Performance. LP ran the car on the dyno with the current spark plugs in it. Before the hondata was installed, I used to run NGK Iridiums, but they had a tendency to burn at too high a temp and blow, so I want to avoid using Iridiums. Does any one know where I can find NGK standard spark plugs or a sutable replacement? Advance Autoparts, Autozone, and O'Reilly Autoparts no longer carry standard NGK plugs.
first of all i run irridiums and make over 400whp just fine.
secondly if youre talking about the vpower plugs then oreilys and advance and such DO carry them.
96civic cr-v
Spark Plugs
Post by 96civic cr-v »
Bkr7-e ftw
over 500whp on pump gas!!!! :)
BlueDevil
Spark Plugs
Post by BlueDevil »
I looked up those BKR7-E spark plugs. I've found a few places I can order them online from, but I've come across another issue in the process. None of the sites, NGK, NGKus, NGKuk, JEGS, etc, show anything except for NGK Iridiums as a match for my engine. My car is an 04 civic si, with the K20A3. I have no problem purchasing the BKR7-Es, but not a single site so far showing that they'll fit my car, it makes me wonder if I should risk trying them.
