build a d16a1
CRX91
build a d16a1
Post by CRX91 »
need alittle help i sold my other crx so im working with $800. and i would like to go with bigger pistons and do rods also. i want to do a turbo later but can i build it and run it then put a turbo on. i need some help from people that have built d-series motors before. working with a dohc d16a1
build a d16a1
if your going turbo d you should get :
Ycp vitara pistons
FJ rods
oem or whatever brand bearings
new water pump, belts, gaskets
arp head studs
oem head gasket
thats pretty much the build up of the avg vitara d16 build
build a d16a1
I would also add an oil pump to N2HIFI's list. Alot of your oil cooling/lubrication depends on oil pressure. I would not risk an old pump.
CRX91
build a d16a1
Post by CRX91 »
ok thanks this helps out sence this is my first
