Eg itr build
CourtesyFlush
Eg itr build
Post by CourtesyFlush »
andyjt;213394 wrote:Can you not search or anything? An ITR engine is Essentially the same swap as a B16 into a civic. I know for a fact, probaly at least 40 people on this site have done it. In fact if you honestly need to know how your better of paying someone to do it.
And your parts list... Almost all of that can be had from your wrecked GSR.
well i really want to learn to do a swap myself. so ill just learn from my mistakes even if it takes longer to do the swap. and ya i guess ill be getting everything off my gsr. thanks for the info
Digital Sol;213396 wrote:before purchasing id at least run a compression check, reguardless of miles id at least do a compression check....R's are not usually exactly driven soft
ive shipped a motor before...not a big deal, never had any problems, it wasnt exactly cheap but it all worked out just fine
if you need parts lmk, im running a b18c/jdm spec R swap in the del slo...im sure ive got plenty of spare parts laying around...mounts, fuel rail, intake etc' but im sure nearly all of that is either on your gsr or comes with the swap..its a pretty simple swap..just like any other b series...
thanks a lot. ill let u know if i need anything and yes. im going to definitely run a compression test before buying it.
andyjt
Eg itr build
Post by andyjt »
95acuraintegra;213401 wrote:well i really want to learn to do a swap myself. so ill just learn from my mistakes even if it takes longer to do the swap. and ya i guess ill be getting everything off my gsr. thanks for the info
Why would you not just swap the GSR engine in. You'll have everything you'd need and it be a hell of alot cheaper.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
CourtesyFlush
Eg itr build
andyjt;213402 wrote:Why would you not just swap the GSR engine in. You'll have everything you'd need and it be a hell of alot cheaper.
well i kinda promised it to a friend. he said hed want it if i ever wrecked it. idk...i dont wanna be mean. or mayeb am i too nice?
Dan The Man
Eg itr build
Post by Dan The Man »
95acuraintegra;213404 wrote:well i kinda promised it to a friend. he said hed want it if i ever wrecked it. idk...i dont wanna be mean. or mayeb am i too nice?
idgaf. swap it in if you want
team NOCO crew member #4
Currently Taking A Break From The Game
Eg itr build
Unless you are selling it to him for the same price or more than you buy the ITR for, you are getting ripped off. Your engine is a guaranteed 100% running motor. you know this because YOU have driven it. It sounds like this ITR swap you are wanting to buy is only a partial swap, and you will need to spend a few hundred bucks to complete it... and then you still dont know what kind of shape it is really in because you have never driven it. and you have to try to assemble it all without any experience. Pulling the full swap from your GSR and dropping it into the civic will be a 1 day job and you know it will run when you are done as long as you swap it correctly. With that ITR, if it doesn't run you are left wondering if it is a part missing, a bad motor, or an error in your swap process. Not exactly the feeling of satisfaction you are looking for at the end of your first BIG project like this.
I know that you promised it to a friend.... just tell him that the motor you were looking at fell through and you need to keep the gsr. Nothing wrong with keeping your own stuff. Plus, the money you save on this deal can help fund a few upgrade parts that you may want for the car.
CourtesyFlush
Eg itr build
Spork;213418 wrote:Unless you are selling it to him for the same price or more than you buy the ITR for, you are getting ripped off. Your engine is a guaranteed 100% running motor. you know this because YOU have driven it. It sounds like this ITR swap you are wanting to buy is only a partial swap, and you will need to spend a few hundred bucks to complete it... and then you still dont know what kind of shape it is really in because you have never driven it. and you have to try to assemble it all without any experience. Pulling the full swap from your GSR and dropping it into the civic will be a 1 day job and you know it will run when you are done as long as you swap it correctly. With that ITR, if it doesn't run you are left wondering if it is a part missing, a bad motor, or an error in your swap process. Not exactly the feeling of satisfaction you are looking for at the end of your first BIG project like this.
i like this idea if i cant find an already build car that id like to buy. thanks for the advice!
Dan The Man
Eg itr build
Just an fyi im "the friend" and I support whatever bret wants to do, He's the one that needs to be satisfied with what he's driving.
