z6 help
ls hatch
z6 help
hello.. my buddy just traded for a civic.. it is a 93 hb.. im pretty sure the z6 didnt come in this car.. if anybody could help me id like to figure out what they had to do too get the swap in and and if the engine harness from a z6 will pug into the factory harness.. because they have the b7 distributer on the car.
z6 help
The D16Z6 is an easy swap for the '92-'95 Civic DX/CX/VX. The motor will bolt right in using the D16Z6 mounts. The D16Z6 distributor and ECU are required for it to run right. As for wiring, we need to know what model your friend has. DX, CX or VX?
B16inside
z6 help
and in that case i assume si if the z6 was stock i dunno im tired its 130 i shouldnt even be replying.matt;208824 wrote:if it has rear disc it was stock
but matt he said he thinks the z6 didnt come with car so i doubt it was stock i mean its his car i think he knows best.
96 swapped dx coupe
z6 help
none of the eg hatches weighed anywhere near 3270. if its an SI it will have a sunroof and rear disc like others have said. SI's came with the d16z6 from the factoryonecam12sec;208854 wrote:look at the weight in driverside door. it should be like 3270 for si. also power sunroof. if not ,unless it's a vx(no side moldings or ps, and tach redline 6500), you will need to run wire for vtech, if not already done.
Racecore.com
Racecore.com
