ecu and harness question
motrayeg6
if i have a p73 ecu and get a obd 1 harness will the harness and ecu match up? or do i need to get a obd 2 adapter? i also have a p28 ecu laying around would that work for my gsr/type r motor?
You will need the appropriate OBD2 ECU to OBD1 jumper harness to use that ECU. The P28 will run your motor, but I wouldn't suggest driving on it since its has the wrong maps.
motrayeg6
thats what i figured ty sir, so i would need a jumper harness for the p73 then?
