calling all b-swap gurus
jadedeg
Post by jadedeg »
Thursday morning my d-series took a dive on me and I am looking for anyone, who has done a b-series swap. i am getting parts together today and tomorrow and I am planning on doing the work on Sunday; if anyone wants to come over and help out. I have never done a swap before and probably need some guidance. This is my dd.
Devil Crx
Post by Devil Crx »
wow, do you really think you'll have everything you will need to get it done so soon? tranny motor, axles, wiring, etc?
*GMR* CRX Superleggera
kikkinasphalt
Post by kikkinasphalt »
hats gunna take some cash sir...
'98 CSVT.. stock
Post by Clayton »
some info
Engine
Tranny
Clutch slave cylinder and line
Hybrid Engine mounts and t braket
Shift linkage
P75 Ecu and for it to be chipped
Axles
Coolant hoses
Clutch
Flywheel
Throw out bearing
Pilot bearing
O2 sensor
And other seals and gaskets
You will also find that when you go to start it up there will be cel on and then you are going to have to replace sensors that are going bad on a used motor
this is not something you just do in a weekend. it takes time to track down parts
Post by RyanA »
If this is a 92-95 car, there is only one way I'd do it.
Buy complete LS swap from a 94-95 Integra (there was one for sale on KCSR for $900)
Use mounts that came with Integra
Use harness that came with Integra
Use ECU that came from Integra
Use axles that came from Integra
DO NOT open the hydraulic system for the clutch. Just unbolt the slave from the trans and bracket and lay off to the side, holding it with zip ties. Once you get the B swap in, just bolt it back on.
Do swap through the bottom using 2 floor jacks. Everything will plug in directly and the mounts will also bolt right in. If you want to keep AC, you need to get a CRV P7J bracket. To keep PS, use the LS PS pump and brackets and simply put your lines right back on.
EDIT: If you do the swap through the bottom, the T bracket needs to be in the car when going in and coming out. Once the engine is in, start the top bolt first (through bolt) then you can just grab the engine and rock it to get the other 2 started. You need to attach the driver and passenger mounts to the car after you start the top T bracket bolt but BEFORE you do the lower 2 T bracket bolts; just a little easier this way.
Post by 90CivicEx »
I've done a few and some go easy and some just become nightmares. Give more info on what your planning besides just saying hey I'm throwing a B-series in my DD.
Devil Crx
Post by Devil Crx »
So, How'd it go?
Post by Clayton »
i swapped him in a d series to get him going for now he will save up and get everything going for his b swap.
Devil Crx
Post by Devil Crx »
sweet, glad that things worked out and you were able to help him out.
