B16 siezed
Miggyp17
B16 siezed
Post by Miggyp17 »
so i have a b16a and it seems to have siezed up for some odd reason
its unsiezed now with a little atf and a breaker bar
so i broke it down like this
started with the oil pump seems to be fine
i took the head off
and the oil passages seem to be not blocked
what could be the possible reason for the sieze?
ive thought bout just throwning it back together and saying goodday
but i mean im afraid its gonna seize again.
RIP - 91 HB d16z6 turbo - RIP 91 HB b16a
B16 siezed
Post by Phate »
Where are my crx parts?
B16 siezed
Post by Gunmetal Si »
Phate;143182 wrote:Where are my crx parts?
better answer that mofo, cause he aint nice when he doesnt get anssers.
on a differnt note, what have u done to it in the past that warrants it to act this way?
B16 siezed
Miggyp17;143178 wrote:so i have a b16a and it seems to have siezed up for some odd reason
i took the head off
What exactly did you do to test the oil pump?
B16 siezed
Post by RyanA »
Did you CHECK your oil? Typically, low oil level makes Honda engines lock up.....
B16 siezed
Post by Clayton »
take off your pan and check your pick up tube
Miggyp17
B16 siezed
Post by Miggyp17 »
pick up is clean as a whistle
i took the oil pump apart and made sure the passages werent blocked
the motor was 1quart low at the time of siezure
