ok guys im stumped and need some info
i got a b16a put in a dx hatch running a pr3 its got cel code 7 and 9
7 - throttle position sensor
9 - cylinder position sensor
the car just wants to bog unless its in vtec
from 1-bout 3500 it just doesnt go and from 3500-vtec it is better but then when vtec cracks it just goes no hesitation
b16a problems
b16a problems
try swaping the map sensor wiring connector and the tps wiring connector
Miggyp17
b16a problems
the wiring its 2 diff plugs i belive like its not on the same plug the map sensor seems to be running fine with no codes as well
b16a problems
no cracker he means swap them cause there the same style plug and 80% of people when they swap get them backwards. There hooked to the same loom of wires and have identical clips, its a easy/honest mistake.Miggyp17;139232 wrote:the wiring its 2 diff plugs i belive like its not on the same plug the map sensor seems to be running fine with no codes as well
Miggyp17
b16a problems
wouldnt it be throwing a code for map sensor?
my map sensor wiring and throttle are on 2 seprate looms
so im confused
so im confused
b16a problems
nope. they both run off of a 0-5 volt signal and since they both recieve a 0-5 volt signal even if they are backwards, they dont throw any codes.Miggyp17;139485 wrote:wouldnt it be throwing a code for map sensor?
Miggyp17
b16a problems
hmm ok well they are on 2 diff looms but hell its worth a shot ill try it when i get home
if this isnt the problem whaT COULD BE
b16a problems
but actually, i misread the orginal post. what i was talking about were the map sensor and the tps sensor. so just ignore what i had said.Miggyp17;139487 wrote:hmm ok well they are on 2 diff looms but hell its worth a shot ill try it when i get home
but... the cylinder position sensor is located in the distributor and you will have to replace the distributor if it is bad. do you have an extra distributor to swap out and see if that will fix the problem?
Miggyp17
b16a problems
what dizzy will work
so u can swap the tps and the map tho?
b16a problems
yes, the tps and map sensor plugs are swappable. normally i have seen that cars do not like to rev past 3000-4000rpms and not like to idle when those are hooked up backwards. as for as the distributor goes, im sure other people can answer that question better than i can. i would just be able to tell you that a distributor from an obd1 b16 car would work.
