[/IMG]any ideas of what causes this? i laid a straight edge across it and it wasnt showing that it was warped, ill check it again tomorrow but i am just trying to get some ideas of what it could be.
[/IMG]
thats what i thoughtRyanA;137635 wrote:Either no spark and the chamber got REAL clean or you got coolant in there. I'd honestly suspect coolant. How did that piston look? If it was squeeky clean, I'd suspect coolant over anything else.
Also, Hondas typically run hottest on cylinder 3.
really .. shit .. ok well thanks for that correction .. I was under the assumption from what i have read other places that it was number one.RyanA;137635 wrote:Either no spark and the chamber got REAL clean or you got coolant in there. I'd honestly suspect coolant. How did that piston look? If it was squeeky clean, I'd suspect coolant over anything else.
