Turbod D16z6
Miggyp17
Turbod D16z6
Post by Miggyp17 »
so after a long 3days of working at it off and on
they turbo is complete
the trial drives around the block went good
only blew a couple pipes off after that got fixed we went out and got on it a bit
20 min later white smoke from helll
oretty sure the rings are toasted on the pistons
MaSSaCrE
Turbod D16z6
Post by MaSSaCrE »
what you mean the turbo is complete.You tune it?
andyjt
Turbod D16z6
Post by andyjt »
MaSSaCrE;130833 wrote:what you mean the turbo is complete.You tune it?
Clearly not. :-(
Probaly blown headgasket.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
MaSSaCrE
Turbod D16z6
Post by MaSSaCrE »
sounds like the way he explained it he bolted some stuff on and went for a joy ride.
Miggyp17
Turbod D16z6
Post by Miggyp17 »
ya basically said
the piston rings were bad before it blew oil slighty
so now they r worse
headgasket is fine
JesSi
Turbod D16z6
Post by JesSi »
Why wouldn't you get it tuned first?
Turbod D16z6
Post by mike93hatch »
gawd
Miggyp17
Turbod D16z6
Post by Miggyp17 »
cause i new this would happen already
the rings were bad before the turbo i kinda knew it was doomed to happen
MaSSaCrE
Turbod D16z6
Post by MaSSaCrE »
thats isnt the point lol...the point was why drive it untuned...even if you knew or didnt know that they would go out you should tuned it.
Turbod D16z6
NO.... the point is: why would you turbo a motor when you KNEW the rings were bad? why wouldn't you replace the rings and worry about making sure the motor was sound before putting a kit on it and making the car undriveable?
no you and the mad scientist gotta tear apart the motor and replace the piston rings you fried.
