timing belt-what else?
getteg
Post by getteg »
Ok so I am going to change my timing belt on the teg in the next week or so and I was wondering what else I should change at the same time. I am deff. going to do the following.
Timing Belt
AC Belt
PS Belt
Alt. Belt
VC gasket
Water pump
What else should I change while Im in there? Does the timing belt tensenor need to be replaced? The car has just under 130,000 miles
Thanks
Brian
Post by 90CivicEx »
check the tensioner to make sure it's all in working order, in all honesty I would change it but thats me.
While your working on it I would replace the cam seal if you have not already.
Post by Phate »
Idk about you, but oil pan gaskets are my worst enemy. Also, I'd do stuff like fuel filter, spark plugs and wires, distributor cap and rotor, if you dont know the last time it was done. Just did a friends the other day, took less than an hour with a oil change.
getteg
Post by getteg »
Ya I replaced the oilpan gasket when I did the exhaust and no more leak.
Thanks Fellas
Brian
