P29's or thicker/thinner head gasket
jadedeg
Post by jadedeg »
Hey, I have been reading through and researching...I have the D16z6 and was wondering if there can be any gains made from just installing a thinner head gasket and having a car dyno tuned with normal bolt-ons. Or another option...is it possible to put the p29 pistons into the stock block with a thicker head gasket and stock head? Any info. would be greatly appreciated...been reading for a couple hours at work and see similar threads, but nothing to address this.
Thanks
jadedeg;124574 wrote:Hey, I have been reading through and researching...I have the D16z6 and was wondering if there can be any gains made from just installing a thinner head gasket and having a car dyno tuned with normal bolt-ons. Or another option...is it possible to put the p29 pistons into the stock block with a thicker head gasket and stock head? Any info. would be greatly appreciated...been reading for a couple hours at work and see similar threads, but nothing to address this.
Thanks
You won't see much of a gain, if any by using a thinner headgasket on a D-Series or dyno tuning a D-Series w/ bolt-ons. You can use P29's in a stock D-Series depending on which block/head combo your using. This subject was gone over in this thread a few days ago...
http://stlhondas.com/forums/showthread.php?t=9729
jadedeg
Post by jadedeg »
Thanks for the input. I appreciate it. I am not sure what I am going to do...
