valve ajustment
muha22752
valve ajustment
Post by muha22752 »
hey guys i need a valve ajustment.
should i
take it to a shop
pay my neighbor who is vp at some dealer ship
or just find a write up and do it my self
or if same one wants to help out i would appreciate it
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
muha22752
valve ajustment
Post by muha22752 »
bummp
umadbro?
W.K.D
valve ajustment
Post by 90CivicEx »
Put the first cylinder top dead center and take your feeler gauge and see what its sitting at on the feeler. Once ya know what it's at each lifter has a 12mm nut and a flat head center loosen the 12mm and adjust the flat head to where you can slide the feeler out and in smoothly not to tight but not loose.
The exhaust side is .009 to .011 try to get it closer to .009
The intake is .007 to .009 try to get it closer to to .007
Once your done with the first one repeat on each cylinder then run back through and putting each cylinder tdc and make sure your feeler pushs and pulls out smooth.
In anycase search your motor and valve adjustment specs on google to find a spec sheet to help ya out more if needed.
valve ajustment
Post by bildo16 »
i would have an educated eye there to watch what you are doing, its very easy to mess this up which then becomes a big headache.
