Timing help
sn95guy
Timing help
Post by sn95guy »
even after i change the tooth, it still cant get a reading in the 3 lines... gets close to it, but wont make it all the way forward... like its still hitting on the right side of the pointer.. what way should i turn the tooth?
1995 Mustang Gt- Bolt ons and spray R.I.P.
1992 Honda Civic Cx, Swapped, suspension, Wheels
Soon- 97 Cobra- Procharged 12lbs, full exhaust, gears, drag radials...
Timing help
Post by 5thgen »
how are you aligning the head with the crank?
and a whole rotation to tension a belt....damn....
sn95guy
Timing help
Post by sn95guy »
like that, i get the bottem lined up at the pointer, get the top flat with words up going up, then slide timing belt on... then when i start it, its about 3/4ths of a inch to the right of the pointer is where the marks are hitting... so does this mean when i take the belt off the cam should i turn the cam front or back 1 tooth?
