Who is running an LS/VTEC?
i know chris and allex are.
are you guys using ARP rod bolts?
Those of you running an LS/VTEC!! pleas read
eh2_Erik
Now s13_Erik
uh... arp rod bolts are important if you plan on revving higher than a stock LS
http://hondaswap.com/general-tech-artic ... tec-70187/
yes ARP's are required if you plan on making any power or reving over the factory ls redline.
and yes i am using them now and alex will be using them when we rebuild his motor
I got arp everything, rod bolts, main studs, and head studs.eh2_Erik;114033 wrote:Who is running an LS/VTEC?
big pipe
my brother is building one that hasn't ran yet/
he's got 'em
i would suggest every bolt taken out of your engine gets replaced with ARP
he's got 'em
this space for rent
i don't recommend running arp mains unless you have your block line honed , apperently since you tourqe the main studs down more then factory specs it has a tendency to pull the crank mains out of wack and cause premature bearing wear.
so i am using arp rods and head but stock mains that way i dont have to worry about this issue and stock mains are plenty for any na motor.
eh2_Erik
Thanks for the feedback guys.
so i'll be okay running my stock rod bolts, just as long as i dont rev to high?
because im on a tight budget for this build and i dont got the funds to have that done.
What would you guys recommend me doing? how long has allex had his like that?
Now s13_Erik
damnit*
I did not have them on my LSVTEC, but I didnt rev past 7k either. Wish I wouldve though, mightve saved the engine from rod bearing failure.
take this to heart .. if your not going to spend the money then dont do the conversion .. you will NEVER get the performance out of the motor if you don't do the rod bolts.eh2_Erik;114109 wrote:Thanks for the feedback guys.
if your short on cash you should not be trying to mod your motor. The arp rod bolts are dirt cheap and worth the money, 60.00 to know your motor has less chance of blowing up when you over rev it from miss shifting. And don't say you wont because i Did and i am about 5g in the negative because of that little mishap
http://cgi.ebay.com/ebaymotors/ARP-Conn ... enameZWD1V
eh2_Erik
but how much would it cost to get them installed?
Now s13_Erik
